A flat with two floors above. One 40mm waste pipe to a common stack from shower tray and one 32mm pipe teed into this from from the basin. The stack only takes baths and basins. An AAV would improve the speed of flow from the bathroom shower tray. The AAV would be above the basin water level. The AAV is supposed to be above the the highest water level, usually the basin. In flats that is not the case with the common stack, unless you are on the top floor.
I see that this company
https://www.studor.net/high-rise-applications
had them fitted in a block in Manchester.
Has anyone done this? Are AAVs allowed in flats?
thx
thx
