Hi All,
bit of a long one so my appologies.
I wanted to take the rad off in my kitchen but one of the valves was stuck so I thought I'd try to draing the system and replace the valve and rad at the same time.
I proceeded to drain the system but only got a bucket full of water.I tried opening the bleed valves upstairs and only a little more water came out.
I checked the header/expansion tank and that was full. I spoke to a friend (plumber) who came round and fitted some isolation valves on the pipes for the new rad and said I should be able to use the hot water still and he left.
However because the system is only half drained, I now have a load of air in the system which I can't get rid of and it seems the boiler/pump can't pump it round. The boiler kicks in but only for about 10 seconds, then won't fire up for another 20 mins.
Can anyone suggest how I can force the air out or more water into the rads from the header tank please? The pump is working overtime and is extreamly hot although the pipes everywhere are stone cold.
Many thanks,
Tom
Many thanks,
Tom
