Air brick cover needed - odd size!!
18 Aug 2006
Warwickshire
I need a sliding air vent cover for the air brick in my bathroom.
Unfortunately whoever put it in originally made it so that the standard size covers will only fit sideways therefore I can only slide it up and down rather than side to side so it either stays open or closed!!
I thought if I could find a bigger one this would solve the problem but they all seem to be 229cm does anyone know of any different ones?
many thanks
hey be hard to find that size ,why dont you make a frame out of plastic to just cover the hole then use any air vent type you want over the top of it  8)
Without taking it off again it's about 9" x10" the existing cover is only a bit too small to go on the right way.
