Hi all, I was wondering if anyone could help me? I had a new block paved drive fitted a couple of years ago and they raised the level of the ground by a couple of inches, meaning two (already low) airbricks were covered or partially covered. They kept a trench around the air brick (first photo) and filled it with gravel, they said, to aid drainage. I have noticed damp recently inside the house around where the air brick is and so dug out the gravel, which seemed to stop the problem reoccuring.
My problem now is how to cover the trnech they left. My idea is to cement a one brick high border (photo 2) around it, to stop water that runs down the driveway from going intot the hole and then put a wire mesh over the top to stop leaves, and general rubbish from filling the hole. Do you think this would be acceptable or does the hole need a full cover to stop rainwater entering directly as it falls? ie a plastic drain cover?
I know now that they should never have covered the air bricks but it's done sadly, and taking up the drive really isn't a feasible option.
Any advice or help would be greatly appreciated.
