I HAVE AN X REG CITROEN XSARA PICCASSO. THE AIR CONDITIONING IS NOT WORKING. THE LIGHT ON THE BUTTON COMES ON WHEN PRESSED AND NONE OF THE FUSES HAVE BLOWN. ANY IDEAS WHAT MAY BE WRONG?
Probably needs regassing.
Go to a proper air con specialist and have it cleaned out / tested and regassed rather than a garage who will just top it up.
Hi, quick fit do regassing, just had mine done, and for £45 its pretty cheap too, its all automatic, so all the guys in the place do is connect the hoses, put in your car info and off it goes, it de-gasses, vacuums it, removes the moisture, leak tests and re-gasses in about an hour, and if it dont work, you dont have to pay.
