Hi we have 3 toilets and the main one in the bathroom sounds like it might have air in the pipes.If we flush that toilet and then say switch the shower on straight away it sounds like a neumatic drill going off. How can we cure this problem please?
is the noise there if you only flush the toilet and not run the shower after.... If so it sounds like water hammer. Check the float valves in the toilet for wear
