Hi all
I have an open vented system and a problem i cannot figure out
Basically i seem to be getting air in to the system continuously and i can vent a little off after the system is used for an hour or so (definately air as have done the lighter test!).
This occurs if i use the boiler for hot water or heating so i am guessing the problem is not in the heating circuit?
I tied up the header tank ballcock and after a few days checked to see if had gone down-it had not so i assume i do not have a leak, also checked what i could see of all the rad pipework coming up out of the floors and could not see anything.
The system was power flushed a few months ago and a magnaclean installed directly after the pump. this involved shortening the feed and vent pipe by 2" to make it fit so i am wondering if it could be drawing air in via the vent?
Can anyone help me find the cause of this and how to go about fixing it?
I want to fit a new header tank next week with closed fitting lid so i might raise it a foot or so and the feed and vent pipe if that might be the cause.
Could i block off the vent and run it under supervision for an hour to see if it stops the air?, failing this i am all out of ideas.
