I have a conventional CH system. CF boiler with 8 rads and gravity fed hot water tank which has worked problem free for many years. Last week I heard loud noises from my pump which appeared to sound like air in the system. I checked the rads and found 3 with a lot of air in. I have checked throughout for leaks but can't find any. If I bleed the radiators the pump continues to make the noise and in a short time they are full of air again. I checked the header tank and found the water in it warm and murky. The outlet pipe (ch feed) from the tank is warm and the overflow seems as though it could have passed water (wet in the pipe).
Any advice appreciated.
