Air Pressure Switch?
18 Sep 2009
Hi
I have a Baxi 105 condensing boiler, 3 years old, and it will not fire unless the case seal is off. Is this an APS related problem?
Thanks in advance
Firstly, why are you breaking the combustion seal if not qualified? :roll:
don't start all that putting the world to rights.
Fair do's..... had a bad day following beefcakes around who cant wire a replacement programmer without causing an abortion....
To the OP, yes could be the APS, could also be a dirty fan, mucky venturis, flue problem etc....
Sorry to be a bore but I would echo Dave's advice that if you are not gas qualified you should not be playing with combustion/safety devices.
Why do you think that you are safe to work on them?
Tony
