Not if the other rads got hot as the pump must be working.
Are the two rads that are not now getting hot on the same single drop?
If so you may have a blockage in the pipework to these radiators or more likely an air lock.
Open up the rads that work and the 2 that dont and leave the system running most times the air will work its ay round to the AAV and the system will sort itself out that way.
