I have a sealed heating system with Vaillant Thermocompact boiler. It was working fine then yesterday I drained it to fit new radiator and revised pipework in hallway with new drain off valve.
Before refilling the system I noticed the filler loop check valve screw was weeping water and was stuck, so I fitted a new similar one R24 from Screwfix, also with non return valve but now two black valve knobs, no fiddly screws.
I refilled the system and bled radiators bottom to top of house. All air appeared to be removed and pressure was up at 1.5 bar, as heating engineer had earlier advised and written on the boiler. That was last night, no apparent problem so far, very small amount of air in system but that could be bled out over the coming days.
This morning I noticed the pressure was at 2.2 bar, too high? So to reduce it I tried what I have read, to uncouple the filling loop 'in' end and opened the service valve to let some water out into a bucket and pressure on boiler would drop. Nothing, no water, that must be the non-return valve stopping water coming back. So I opened the new drain valve in hallway and let water out via hosepipe, approx 6 litres I would think, to reduce the pressure - was that wrong?
I then put boiler heating on, turned it off after a few minutes, let it settle and bled the radiators again, lots of air came out but the pressure has only reduced slightly to 1.9 bar. Turned boiler on again and there is clearly air in it. When it fires up the temp rises then races up to approx 90 deg C then cuts out. I can hear air or lack of pressure in the boiler and have turned it off. Tried again but it won't clear the air or fire up for long. There is a small separate expansion vessel but can't see the schreider valve normally on them, it's also pretty inaccessible, hope I don't need to go near that!?
What have I done and how can I put right what had until then been quite a successful job? Seems like I have screwed up the last stage, or worse?
Your help would be much appreciated.
