Air vent required for open gas fire?
  • Thread starter Thread starter HiZ
  • Start date Start date
H
HiZ
As per subject is one needed for a large sitting/dining room. Burner is 6.85kW max.
Did I remember 10cm squared of free air is needed for anything over 7kW. Below that your OK?
Plastic windows and patio doors fitted. One wood door to hallway.
Anything below 7KW is o.k. no additional ventilation required due to adventitious ventilation. ( The natural ventilation between cracks in doors, spaces in windows. etc).
Call me suspicious but do you happen to have a copy of M.I.`s in front of you & are just testing the knowledge of gas engineers/installers on this forum :?: .....you seem to have a fair grasp on outputs & ventilation requirements for a Diy`er...
unless its a dfe ( decorative fuel effect) fire you dont need an air vent for gas rated input of 7kw or less( usually known as ilfe or inset live flame effect)
if its a dfe then u need 100cm2 mandatory
Manufacturers Instructions take precedent, your local Corgi gas Installer will put you right..
Bamber gaspipe
Cant beleive that is right.
I can beleive that
Diyisfun said:
Bamber gaspipe
Believe it.. because it is correct.
Bamber gaspipe
Now dont start on me
BUT
I reckon that CORGI must take a precedent over the manufacture.
You `reckon` wrong..I am not starting on you, merely stating a fact.
not in all cases some say they dont need 100cm2 in the manu,s instructions
Diyisfun said:
kevplumb
it is correct the MIs overrule the corgi lot
Im surprised...Bet Corgi, dont like that
Its none of their business, manufacturers make and test it and know what it requires to burn safely.
Its very dangerous for an RGI to "think" that he knows whats required!
With a gas fire the MI have to be read first as many do require ventilation even if the heat input is under 7 kW. ( Why do I think of 6 kW for gas fires? )
The reason RGIs fixate on 7 kW is because you disregard the FIRST 7 kW when calculating the ventilation requirements of an open flued appliance.
Thats what the regulations say! In my view they are now wrong and potentially dangerous. This arises because UPVC windows are virtually 100% airtight and the same goes for the laminate floor.
Tony
So you do a spillage test on dfe that does not require ventilation, it passes, the room has pvc double glazing and a laminate floor, what do you do, ID it. :roll:
