I'm replacing my old unsleeved airbricks with sleeved ones to try to improve ventilation to help with damp. I'm placing three underfloor and one (double one) at just below ceiling height.
I've read up on it a fair bit and the consensus seems to be that it is within my basic diy capabilities and overkill to hire a pro for this job.
Since the underfloor ones are below the level of the dpm i don't think I need to also retrofit cavity trays above them.
My problem is that the sleeves are supposed to angle downwards from inner to outer leaf to guide any water that gets on them to the outer wall to evaporate off over time. However the bricks do not line up in such a way as to achieve this and the sleeve would be lower on the inside - a definite no no!
What can I do about this? Is there a diy solution? Is it ok to cut into the bricks so that I can get space to slope the sleeve the right way or would this weaken them? Many thanks for any advice.
