I have an Aiwa hifi model cx-81mk and need radio tuning instructions it has 20 station memory pll quartz I have tried tuning and when I turn the system off I lose them please help.
I dont have a manual,I thought the search was stored but when I turned the system off and pulled out the plug the next time I turned the system on the stations werent there.
First off, don't bother tuning all 20 stations. Find a method that lets you store a single station. Once you know that it work after a power off/on cycle then you can tune the rest of the presets.
With most radios there's a Preset or Store button on the front panel. Tune in one channel. Press and hold in the Preset button. The display may change to confirm the station is stored. Test it by changing the tuning and then pressing 1 to recall the preset.
If this method doesn't work then there might be other buttons involved such as Store.
Did the methods here help (say Yes or No) or did you find a different way of doing it - if so, what was it? This may help anyone in the future with a similar Aiwa stereo system. Thanks
