Satellite radio
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I have no FM reception, no DAB reception, so to get to radio 4 I have to use the TV. I know with the cheap old satellite boxes there is audio out, but need some thing to see what I am tuning to, so TV on, select channel then TV off.
But is there a satellite radio made? So I don't need it linked to TV to select channel?
You could probably do that with a s/h Sky box.
No need for the TV to be on. Press SKY to switch on box if off, then key in 0-1-0-4; hey presto, Radio 4. All the radio stations work in the same way.
As long as you know the channel keying sequence then I dare say a small Freeview box would work in a similar way.
The only thing to be aware of is either miskeying or not having the remote pointing at the box for one of the key presses. I use/program/supply touchscreen remotes that use IR relay kits to solve this issue. They're pretty-much bulletproof in this respect.
the humax foxsat HD box has a numerical display on the front, so it should be easy to just remember the relevant numbers and select them directly without having a tv. and it has audio out phono sockets on the back!
https://www.ebay.co.uk/itm/Humax-FO...815838&hash=item2cf6ac31fe:g:FsAAAOSwbXpdh5iq others are available from the same site, but check your local gumtree as well
ps dont get the newer smaller box as that doesnt have a display
