hi guys
I've been having some very intermittent faults with my Accenta G4 (previously discussed on here) & I found one of my alarm cables has been pressed near flat by a badly refitted floorboard. It goes to the hall PIR. The system has been working ok for the last 3 weeks or so, but the fault is very sporadic.
I'm obviously going to cut out the damaged part of the cable and solder back to create a sound joint. Whole cable replacement is near impossible as it's buried in plasterwork by the control panel.
What sort of faults can you get with a flattened cable?
Cheers!
Cheers!
