- Joined
- 8 Mar 2010
- Messages
- 341
- Reaction score
- 8
- Country
What ho one and all,
Leaving the house today and pressed the Set button on the Accenta Mini Gen 4 RKP, only to get an immediate beep, beep, beep from the external sounder. It was not the normal alarm sound, but certainly sound more like a warning noise.
Additionally, the red 'power' led on the RKP is flashing at around 10 second intervals. Un-setting the alarm, and the sounder beeping continues for around another 30 seconds.
Cannot find any reference to the issue in the manual but would appear to be power related. I will check the control panel fuses and the date of the back-up battery but of 'greater' concern is the back-up battery in the Reson 8 external sounder. It is a 6v Ni-Cad and has never been replaced in the 15 years since installation. (I only use the term 'greater' concern because that requires tallish ladder work to replace it.)
Presumably, the Ni-Cad should be replaced but the manual has no mention of a life expectancy.
Checked the control panel and mains fuse and all good.
The 12v back-up battery has my sticker suggesting to renew July 2023 (could that be the issue?) but is registering 12.2v
When everything is connected again, the RKP is just displaying a single row of black boxes and the sounder is beeping. Upon setting the alarm, the countdown beeps start and the sounder did do its thing, but upon un-setting, the sounder beeping continues.
The only two possibilities in my mind are the 12v battery and/or the 6v sounder Ni-Cad.
Grateful for any thoughts or suggestion as to any other possible causes.
