Hi All
Just in the process of installing a new basin and its higher than the previous one meaning that the existing waste is too short at the wall end and too high at the basin end.
Whats the best was to resolve this , i notice that you can get flex ones but they all seem to be 320mm in length which is a bit long really. This install has been really tricky. whats the easiest way to get these to line up? Hold it there and then put the pedestal under?
I did notice that you can get a shorter flexible fitting which starts at around 150mm but this one has compression at both ends, i need one that will fit directly into an elbow (push) at one end and then screw into the waste at the other
