Alkathene fitting issue
10 Dec 2008
Jersey Marine
I have a 32mm Alkathene pipe that terminates on a one way valve on a pressure vessel.
To make the connection these is a metal Alkathene fitting .. consisting of a nut, compression Olive, space and an O ring.
The nut then screws onto the pressure vessel fitting, pulling olive tight onto pipe and spacer presses O ring into groove in the fixed half of fitting, and the O ring making the seal.
Picture here of the pipe end fittings.
http://i771.photobucket.com/albums/xx351/Tafflad/DIY/alkathene.jpg
The O ring is damaged .... anybody know where I can get spare O rings ... size is 3.5mm x 32mm
I estimate 3.5mm as it is different at every point I put callipers on.
The designation on the fitting is :
DVGW G.PN4 WPN10
(The DVGW tells me is is German water systems standard)
Tried local plumbing & commercial plumb centres ... all their alkathene fittings are plastic not metal ... no option to change to plastic as it has to work with existing pressure vessel.
doesn't really need the pic .. the Q is anybody know where I can get a 32 x 3.5mm O ring ....
I have loaded url again anyway.
I did try that ..could only find 32 x 3
That would be too thin .....if you know of a site fit 32 x 3.5 do tell.
I know of Bearings outlet and a Hydraulic specialist locally .. will try them out.
I was focussing on Plumbing as it was for Alkathene pipe.
