All in one unvented system for water and heating
7 Sep 2013
Kent
Hi
I am looking to get a megaflow or take tribune installed in my house. CN these types of systems run the central heating aswell? If not, is there an alternative that isn't a combo boiler?
Anthony
A thermal just stores some hot water and a load of sludge.
It won't heat any rads.
You don't have to have a combi, an unvented cylinder will run off a system boiler and that will do your heating as well. If you want a single unit rather than a separate boiler and cylinder, look at the GlowWorm Ultrapower
Thanks for the replies! I took a look at the gloworm, by the looks of it it should provide aStrong pressure by itself, does that sound right?
From what you have said I would lean towards an indirect unvented system which will give me mains pressure and allow me to heat the rads with the same boiler. Have I got that right? Also, the unvented system could go anywhere on the property and deliver the same pressure?
