I really need some help here please.
Glowworm 18 hxi boiler with unvented system. 15 rads.
Radiators were only warm and then hot water was no more than tepid.
Plumber replaced pump and advised system required flushing as too much crap in the system.
Came yesterday and used power flusher for a few hours.
Then tried boiler again but it kept shutting down due to temperature getting too high. It seemed the water was not flowing properly.
Drained and flushed system again and tried again - no joy so we were left overnight with no hot water (save immersion) and heating.
Came this morning and changed pump again - no joy so took heat exchanger off and cleaned / flushed. Replaced and still no joy - boiler kept cutting out (thermistor error or no flow).
Put more Fernox equivalent in system and kept trying to get boiler going but with no luck.
Left us with the news that we should leave the boiler going to let the cleaner work its way through the system and hopefully the blockage will loosen and then allow the water to flow.
So far no luck
Water pump is boiling hot as are pipes near it but any further than 3 inches from pump and pipes are lukewarm. Water is hot though (4 yr old and 6 yr old daughters had a bath!!).
No hot water getting to rads although pump sounds to be turning
Boiler makes banging / grinding noise as temperature approaches 80 - then cuts out.
Been advised also, if this doesn't work we'll need new heat exchanger at £300 ish.
2 questions -
Anyone any better ideas?
Should the crap have got into the heat exchanger in the first place or are the pumbers at fault?
ps: Sorry this is so long and if you got to the end without falling asleep....congratulations.
So far no luck
2 questions -
