Hi everyone,
My boiler, which has worked fantastically for the last 2 years thanks to your help on previous problems, has developed a problem for which I cannot find an answer to in the faqs.
DHW works fine, a bit too hot if anything, but CH fires up only for 30-40 seconds makes a slight wooshing noise and cuts out only to fire up again several minutes later (3-5 minutes). As long as the pilot hasn't cut out the cycle is repeated and over time the rads do heat up although not as hot as before and one is less hot at the bottom than top. The big trouble is that the pilot often cuts out sometimes very quickly although sometimes it lasts a day or more.
In the last 3 years I have fitted a new heat exchanger, diverter manifold/valve, and auto air vent and it was running fine till this artic freeze.
My logic tells me it is overheating but it doesn't dump water, doesn't leak anywhere and the pressure remains fairly constant (expansion vessel is at bar. I have drained and refilled it, checked pump function, fan, everything, I can think of. Any ideas what it could be and what repair I am looking at?
Wendi
Wendi
