I have a Alpha 280E which, when switched on, produces hot water to the rads even when the selector switch is turned to DHW only, the CH stat is turned to the lowest setting and the heating is turned off on the timeclock!
The boiler continually fires up then stops, then fires up again. This means the house is red hot all the time the boiler is switched on.
The CH neon does not illuminate.
Prior to this happening, we had a problem where the rads got warm when the DHW was called for so taking advice, refurbished the diverting valve which was pretty bunged up.
Now we have this problem.
Both flow switches are energised (rods stick out) when the power is on but the primary flow one de-energises when switched off.
Could it be the main pcb?
