Alpha boiler stopped working
Hpd
23 Feb 2011
Cardiff
Alpha CD30s
Neon light B is flashing, and the manual says that’s the Overheat Thermostat.
I’ve tested it for continuity and it seems fine. Also tested the temperature sensor and flue sensor both seem fine. Anyone got any other suggestions? Perhaps it’s the PCB?
Should add the the pump and fan both come on but then nothing happens and the light flashes
Perhaps you shouldn't be messing with a gas appliance or seeking advice where rules don't permit gas advice in an open public forum.
  • Thanks
Reactions: Hpd
My first post here was about an Ocean Alpha 240p combi. I was given the answer to the problem that I had.
The OP is testing sensors, he doesn't seem to be touching the gas side. I don't see an issue.
  • Thanks
Reactions: Hpd
Alpha CD30s
I am neither a plumber or electrician, but I think you need to test the resistance of the overheat sensor rather than just confirming continuity.
  • Thanks
Reactions: Hpd
Thanks for the suggestion. I forgot to mention I did also test this and it was 0.1 which I believe means it’s good
How much does a new overheat sensor cost?
About £40 I think. Worth a go? Just wondered if there are any other suggestions to check first.
Also yeah I have no intention of going near the gas side
Wait until one of the qualified people respond. If it were a tenner, I would say go for it.
  • Thanks
Reactions: Hpd
overheat sensor on top of heat exchanger then its a new heat exchanger as the part is not available so it would be more cost effective to change the boiler
  • Thanks
Reactions: Hpd
Flue sensor and mention of PCB, so can be gas related. Also some covers form part of the combustion circuit, not chamber but circuit, so air side, which can all form part of gas work. Gas work as defined in the regulations doesn't mean just breaking into a gas supply or touching gas side.
