I really hope you can help, not sure if i'll be able to fix the problem myself but at least i'll know what to look for when i call out a plumber and hopefully avoid getting ripped off.
Anyway, to the issue itself. The CH seems to be working perfectly, all rads heat up and stay constant. When i turn on the HW tap full flow i get hot water for a few seconds then it starts to run cold. If i slow down the flow of the HW tap it eventually starts to get hot again (this is how ive managed to run myself a bath!) but as soon as you run it faster it goes cold again.
I've read a few posts on here and think it could be a divertor valve or DHW diaphram but if you could confirm that for me it would be appreciated, and any ideas on how much this should cost me to get repaired if possible?
Many thanks in advance
Edit - Just wanted to add that all the lights on the boiler appear to be operating normal. B light flashes once every 5 seconds, and remains on when the boiler is in operation.
