Alpha CB24
12 Sep 2009
Yorkshire
Hi
I have an issue with my boiler, basically when the CH is on and you request hot water it comes through fine but once you turn off the hot water tap the boiler starts trying to fire up (if that the word) like its switching back to CH but then cuts out again, and keeps doing this so starts up (B light comes on) then goes off again.
It doesn't actually switch back properly and you have to turn it off for a while and let it settle before it will then function as normal on CH
Any pointer would be much appreciated
Diverter valve?
thanks
