Hi, Hope some one can help...
Our Alpha Cb24x boiler started tripping off (`A' red light flashing) without any real known reason... Whether just central heating on or when domestic water is switched on.... Sometimes 2 or 3 resets are required to get warm water thro, for washing up...
I had boiler serviced a few weeks ago after this started (whole set of issues there with the "engineer" sent but eventually we got a service completed..)
BUT, no change from the boiler, still tripping, requiring resetting... (had to get parents to check house whilst we were away on holiday, 3 days out of 8 boiler had tripped)..
Typically this happens once or twice a day, with boiler on in mornings and evenings.....
Diagnostic info on instruction manual suggests that this is the Over Temperature switch tripping (i.e. water too hot), but service engineer checked switch with meter and found no fault - although we couldn't replicate the problem whilst he was present....although as soon as he went it tripped & required re-setting...
His advice was to wait until a component fully failed but other wise he couldn't suggest a fault...
I replaced the flow switch today, just to see if that may effect it - as they are cheap enough on Ebay, although the old switch works ok with a meter...
Any idea's ?...
Oh, our diverter valve looks as good as new, no external leaks or corrosion.... I am wary of stripping anything plumbing wise to avoid leaks & creating seperate issues....happy to replace parts if they fix the problem... I am a reasonable car mechanic, so not afraid to dismantle anything, I just have never had to drain a plumbing system..
Thanks.
Any idea's ?...
Thanks.
