Hi all
I have been having problems for a few months now.
In the summer hot water wasn't instant, it was hit and miss, could take turning on the hot tap twenty times before i'd get any hot water. The plumber changed the diaphram, was ok for a few weeks then the problem started again, so the same plumber changed the switch.
Was ok for a few weeks, then we'd get hot water but it would go cold mid flow, the pilot was going off. This happens most od the time now, although sometimes there is no problem.
Also, the heating is a bit of a problem too, the radiators come on, but the wireless thermostat that the plumber fitted never achieves the temperature that I have it set to (22 degrees) very lucky if it reaches 18. When the heating is on the pilot comes on, goes off, comes on, goes off etc.
Any ideas/advice gratefully received.
dingodingo
dingodingo
