Alpha CB28
23 Feb 2007
Norfolk
Now got 2 of these CB28 that are losing pressure regularly. Both about 3 /4 years old. No leaks any where on systems, prv tested and proved ok, pressure in system running normally between 1 bar and 2 bar, all hot water working fine as is ch. Apparently totally normal fully functioning boilers. :?
Do these Alphas have a 'common' problem where they can lose pressure internally somewhere without any visible signs to the eye :?:
Any suggestions gratefully received :)
No they don't have a problem of that description.
Fill system up to 2.5 bar, shut flow and return valves. Wait 1/2 an hour, has needle moved? It's the boiler. No? open valves, does it go down now? It's the system.
Any suggestions Paul? pressure is dropping every 2 or 3 days on both!
cluching at straws gas4you, could it be a pin hole in HE, visible signs burnt off on firing... :idea: :?: :?:
Thanks clf. i had thought about this but I am also clutching at straws and if I had any hair I would be pulling it out now :x
To make matters even stranger, both alphas are owned by members of the same family.
Think I'll go back to the twilight zone :lol:
No not yet, still having same problem. Customer is going to put up with it until warmer weather when I can do tests over a couple of days with boiler turned off etc :wink:
