Alpha CB28 Pressure relief valve removal
11 Mar 2008
Newcastle upon Tyne
I have read and sorted the problem with my boiler's high pressure, by pumping up pressure of the expansion vessel. I am left with a leaking relief valve which I intend to replace. However on my Alpha CB28 the outlet stub of the PRV comes down through a steel plate which is effectivly the bottom chassis of the boiler. This looks like it will prevent me from unscrewing the PRV through 360deg.s to remove it unless I remove a lot of other valves too. Can anyone advise please. Is it an involved job to remove and replace the PRV on this model?
Also I was planning to buy a spare from somewhere like Combiboilerspares.com do I have to be a registered trade person to do that. I am not a trade plummer but have done many DIY jobs in the past so although confident, should I be tackling this or refering to a qualified Boiler engineer for this level of work?
Any advice much appreciated,
Ian
just remove the plastic bit from the brass housing, clean up the brass seat inside and screw the new plastic bit back in.
