Hello again,
Would like a little help with my boiler again.
The boiler seems to have developed 2 problems in the last 24hrs although I suspect that they are linked. It is not firing up to produce HW and although in constant mode for CH it only fires up when it wants to and then shuts off only after a very short period of time, usually less than 1 minute.
With the HW tap open I removed the flow switch and nothing happened.
Could it be that the FS is u/s? For around £21 inc it seems a cheap enough thing to change before having to get my heating engineer out to see me.
I changed the diaphragm in the divertor valve in June '08 and from then until now the boiler has worked without fault.
Any other thoughts and comments would be greatly appreciated.
Thanks again for the help.
Jules
Jules
