Alpha CD25X Boiler
18 Jan 2017
The boiler in my property has worked fine for a number of years. Recently it has been fluctuating hot and cold when I open the shower or tap (although mainyly cold) Eventually if I open another tap and request further hot water the boiler will trip (i.e a constant red LED lights along with green LED 'D' which is permanently lit. If I switch the heating on then the radiators get hot, but eventually the system will also trip (not sure of the light combination). Reading other comeent I assume it to be a blocked heat exchanger or the divertor valve & bladder. The fact that that it trip though makes me think it could be more than 1 problem. Could anyone offer any advice please?
I'm pretty sure you would need a gas safe engineer to work on your boiler.
