altech wireless programmer
15 Apr 2013
Glasgow
hi, i have got a altech wireless programmer model number althc014.how do you switch the timer off.as its new and the plumber set the timer and did not leave the booklet.all i want to do is switch it off and use if and when required. thank you.
Are you saying that you want to completely ignore any time/temperature settings and just turn it on and off as you want?
If so, why did you buy a programmable stat?
I think this stat is the same as the Salus. Try Googling 'salus rt500rf instructions', and see if it's the same. You can then download a PDF with instructions.
Bit naughty not leaving you the destructions.
