Alternatives to Fluidmaster Bottom-Entry Lever & Fill Valve Cistern Pack
25 Jun 2011
Lincolnshire.
Hi all,
Having recently used the above to replace faulty parts (after some issues fitting all now seems well) I wondered if there were any higher quality versions of similar parts that were available and recommended?
For the most part I am happy with the replacement, but the handle is rather plastic and flimsy, I am sure it will last and do the job, but from a cosmetic viewpoint are there any alternatives that offer a more solid handle?
Cheers,
TFT
27 May 2011
Fluidmaster are the best IMO, and the lever version can be operated by a single finger!
Perfectly durable so long as you don't pump it vigorously like the failing syphon you replaced.
21 Oct 2012
Lancashire
I used to fit Torbeck valves but much prefer Fluidmaster with the brass tails.
PRO45B / PRO75B and the relevant cistern repair packs
Never had a problem with them.
24 May 2016
I agree witht he OP, the cheap look and feel of the handle lets it down.
25 Jun 2011
Lincolnshire.
Sorry to be so long in coming back on this - I think they're fine quality wise, but the handles lack the quality of the ones that I am replacing (which are quite old school but pretty) - I will definitely be going with the brass shank (learnt that lesson!), are their any alternative handles for 'upgrades' or if I'm being picky should I just get a button flush?
