Hello everyone.
I have a radial circuit that feeds an UFH matt and heated towel rail via 2 fused spurs. I have done away with the UFH and want to replace with a small electric radiator (330w nominal power / 125w effective power).
I believe I am OK to connect the rad via the feed previously used for the UFH. Is there any reason this wouldn't be the case?
Also the rad is fitted with a 13a plug. Is there any reason I can't change the fused spurs to a socket outlet specifically for use of the radiator.
I plan to clearly label the socket identifying it as being on the 16amp radial.
