i have fitted some garden low voltage lights. i have two circuits - each with 4 x 20w lamps.
the transformer is rated as 8amps.
the flex that was supplied was too short for where i wanted to place the lamps...so i have used 3amp as it is only 80watts going through it.
the circuit is very long.
what i have found is that the lamps that are fitted furthest from the transformer are very dim.
q. if i replace with 6 or 10amp flex - will this enable all the lamps to be equally bright?
please help.
please help.
