- Joined
- 5 Jun 2007
- Messages
- 4
- Reaction score
- 0
- Country
I hope someone out there can help me, I'm just about pulling what's left of my hair out with this problem!!!
I can bleed the upstairs radiators fine when the pump is off - there is a good squirt of water when the bleed valve is open. BUT as soon as the pump comes on, air magically appears in the upstairs rads and there seems to be very little oomph behind it to force it out. If I leave the bleed open, all kinds of wierd and wonderful noises start, beginning with a bubbling noise in the radiator and then a howling sound from the pipework going into the boiler. The downstairs radiators can be bled with the pump on or off, but the build up of air seems to stop the furthest ones from working when I haven't bled the upstairs rads for a while.
I've tried a chemical clean (when I drained it out, the water looked clear), and bleeding one rad at a time with all the others isolated on both the flow and return, but still this mysterious air returns.
I've got a gravity HW/pumped CH system. The pump is a Grundfos selectric on position 2 out of three. The boiler is a fairly old Potterton.
Any help would be greatly appreciated.
