i have a problem getting the led to light up on my amp, (the wire from the radio headunit down to the amp to connect the 2 units together) i have power down to the terminal, also power on the 12v terminal but when i put the tester on the ground terminal for some reason that is lighting to up but very dim which i thought should not light up at all ? could my problem be an earthing problem.
