An end blanking cap for a 15mm compression joint
1 May 2005
Lancashire
Is there a blanking cap that will fit on to the nut and olive left on the feed pipe after removing the 15mm compression joint body.
You want to put a new olive on there too! Olives are single use items, which deform to make the seal!
(this exclamation mark thing could catch on.)
Chris, I sense derision. I read it as meaning compression stop end?
