I seem to be another one with the perrenially failing Baxi 105e.The problem with mine is as follows.
When the DHW is turned on (upstairs or downstairs, it makes no odds), the boiler will fire up, the water coming from the tap gets warm then as soon as it starts to come out of the tap with a bit of steam then the boiler shuts off.
After about 5-10 seconds of water running through then the boiler will kick up again and the cycle repeats.
If I close the tap down to about 1/3rd so it's a heavy trickle then it doesn't shut off and then we can gradually fill the bath or sink.
We have had the diverter valve changed, the big diapragm to the front of the diverter unit has also been swapped, the thermistor and the PCB, after the diverter had been changed it seemed a little better but has now gone back to how it was.
Any ideas as to what it can be? I wondered if it was the pump gobbed up but the DHW doesn't use the pump does it?
Someone please throw us a bone cos I dunna have a clue?
I don't do the work on it myself, a mate who is a plumber but doesn't normally do maintenance work just big installations is the one who opens up the boiler but he is stumped too and doesn't want to just keep changing parts for the sake of it as it is getting pretty expensive.
Thanks for your help in advance
