Another laptop has died.
13 Jan 2007
Gloucestershire
Hello all, help or advice AGAIN please.
After my daughter`s laptop died a while back, I think mine has gone too.
It was running okay, then the low battery light and beeping started, then the laptop went dead, I presume out of charge.
The charger has a light on but it seems the power is not getting from charger to the laptop. I have tried to find a similar charger but still looking as the fitting to the laptop is an odd size.
It is an Advent 6552, 4 years old.
Any advice please.
Thanks again in advance.
Are you using the manufacturer approved power adapter?
Should be a fairly simple fix for a local laptop repair company - probably needs a new power jack.
if searching for advent 6552 power adaptor and one is found that is listed as fitting the advent 6552 then I would expect to get one of the proper size.
what need to be done is to check to see if there is volts at the jack plug on the adapter.
Thank you for the replies and advice, apologies for not replying earlier, it has taken me time to find another charger that fits.
It is defo NOT the charger, so I suspect the connection to the laptop inlet (or whatever they call it has gone).
Thanks again
