another post! This time blown plaster
26 May 2011
Hi All,
I have a room with small plate size areas of blown plaster speckled throughout and have decided I want to patch this up myself rather than taking it all down and starting again.
I think I am fine preparing the surface but in terms of actually applying the mixture to the wall I wondered what the best tools for the job would be? Do I need a hawk and trowel? or can I get away with just a bucket and a trowel to skim?
I plan to use lining paper once done so does it really matter if this job is not professional quality?
I get the impression from my dad that I need to do at least two coats to the level is this sage advice from dad or is it rubbish?!
Many thanks
Alex
if you just want to fill the holes out flush to the existing plaster then you wont need alot, perhaps just a plastering trowel and a guaging trowel.
Easiest method for holes uptp 50mm deep known to man IMO is this -
Dampen down or pva the orrifice
knock up a thickish mix of one coat plaster and apply into the holes
rule off with a straight edge (a peice of wood longer than the hole is idea) dont worry about getting a finish at this point
leave to dry then sand back a little
knock up and apply some easyfill over the top of the one coat plaster and feather out over the original plaster, once that has dried you can sand it back to an acceptable finish, or re-apply and re sand if required in order to get it spot on.
