Hello all
I am a keen reader of these forum and have picked up a few tips that have saved me a lot of money in the past.
I have recently developed a problem with my boiler. A week ago, the radiator was coolish and i decided to bleed it. It let out a lot of air and naturally the boiler low pressure valve tripped. I repressurised the system and turned on the unit.
The machine fired up fine and the pressure rose from 1.5 bar to 3 bar (red line). The heating sits at this until it is timed to go off, then over night the pressure drops again to below 1 bar and the low pressure light comes on. I have then got to repressure the system again.
I thought prehaps the pressure relief valve had not shut properly as I notice some water coming out the waste pipe (not a flow but some slight drips) so i opened it up to try adn wash any debris, but this does not seem to have solved it.
Someone suggested checking the pressure vessels pressure via the valve at the top but not sure what this should be.
I would appreciate any thoughts. I dont think i have a leak as i cannot see any water (its been about 1 week ) and it runs fine when heating is on.
