Another question about replacing cold header tank Vent pipe?
9 Oct 2006
Southampton
Hi, what do I do about the vent pipe from the cylineder? The old tank had no lid so the pipe fed in from the top. It came up above tank then had a 180 bend.
Modern tanks seem to be completly sealed - what do i do please?
you cut a hole in the lid supplied in the bylaw kit and fit the rubber grommet(supplied) on the pipe
which you will purchase with the new tank :wink:
Yeh probably going to buy from SF.
I want to move the tank slightly. Is it ok if I cut the copper vent pipe, and use a bit of speedfit to extend the run, but keep the copper 180 on the end? Not sure if heat is an issue. I do have a resettable immersion.
