Hi.Hope some nice person can help with this
I have a vaillant turbomax 828e boiler around 5 years old.The CH works fine however the HW is only slighty better than luke warm.
I have checked the divertor valve and it appears to be working ok.I also did a test wherby i switched the heating off and let it cool down then checked to see if the HW was was leaking past the valve.The pipe stayed cold so iu have eliminated the valve i think.
My next port of call is the heat exchanger which i plan to remove a flush through.I live in an area which does not suffer from hard water so i was unsure if there would be a build up in the exchanger.
The Boiler will produce reasonably hot water provided the flow rate from the taps is kept low however when the tap is turned on more the boiler cuts of and then refires.This cycle will then continue and the water will become cold.
My theory is that the heat exchanger is partially blocked and the over heat sensor is cutting the boiler off( due to a lack of available water).
Is this theory/solution possible or i am i talking non sense.
Any Help much appreciated.
