Another "what oil to use on a wooden worktop" ques
21 Sep 2007
Sussex
I know there seems to be loads of posts on this, but I couldn't find the answer to my question.....
I bought solid oak worktops from Ikea - seemed like a good idea at the time... I'm happy with the worktops, but I made the mistake of using Ikea's own brush on oil stuff - which is utter rubbish.
I've sanded them down lightly and put on three coats of boiled linseed oil (first coat thinned 50/50 with white spirit as per the instructions on the tin), and they look fine now.
After reading through this forum, the consensus seems to be that tung oil is the stuff to use. So I just wanted to know if I can use tung oil next time the surface needs oiling, or can you only use it if you start from bare wood so that it can soak right in?
It would have been better to use raw linseed, but there's not really much point changing to tung oil. Linseed was traditionally used for oak (as it grows here whereas tung doesn't).
Just look at this list of "similar" topics :roll:
Similar Topics Replies Views Posted
78"x33" Bi-Fold Door 3 112 Fri Jul 27, 2007 4:13 pm
8" x 2" Floor joist - safe to cut a 4" diamet 4 140 Thu Aug 02, 2007 9:45 am
How do you handcut 7" skirting boards 16 800 Thu Jul 07, 2005 9:57 am
Solid wood "floating" shelving in alcove 5 314 Tue Feb 20, 2007 1:31 am
What does "1st fix / 2nd fix" mean? 11 204 Sat Sep 22, 2007 3:05 pm
Thanks oilman.
I thought boiled oil was the same as raw but dried quicker? That's why I used it.
I was wondering what on earth you were on about with your "list of similar topics".... Until I scrolled to the bottom of the page :D
I wonder how they work those out? There are loads of topics that really are similar to mine, but none of them made the list. :?:
