Any advice for fixing....
20 Dec 2009
Kent
Hi
I'm desperate for help to fix a push button toilet -the push button has broken into the fixing hole,which is all part of a sealed unit.I cannot see how to remove the unit to get to the fixings.Any advice on how to sort this out and replace the button would be a big help.Thanks.
Have you got a picture of the toilet?
Normally you would unscrew the outer nut of the push button, then the enclosure of the tank/cistern can be lifted off the tank. This will then give you access to the parts.
