Originally it only started locking out when
The boiler it replaced was a rubbish one and we had a tank etc for the hot water....There we were thinking we'd benefit from a combi! weve had nothing but trouble with it!
in which case the system was probably /most likely ?? an open system ? which is more likely to suffer from sludge/ magnatite/dirt problems than if it was a boiler replacing a boiler on an sealed system ?? i.e combi for a combi ?
Ravenheat in line with most ? manus will probably walk away or in-valadate any warranty with the boiler if the system has not been flushed ?? (may be ?)
overheat situations , assuming that the component(s) itself is not faulty , will generally ? be caused by poor circulation around the system or plate exc
the boiler is of the Atmospheric type , assume gas pressures have been set correctly etc
You need to ask your installer to come back & take a look.
un-likely ?? to be a boiler problem ????????
