Any help on getting power to boiler please ??
16 Dec 2012
Mid Glamorgan
Yesterday I bled a radiator and then my ideal icos he12 boiler has knocked off.
I checked the pressure and it was below 1, so I have used the filling loop and raised the pressure back up to about 1.7, but I have no power to my boiler still. Looked at the manual on how to light pilot light but no joy.
changed fuse to.
Has some sort of switch tripped ?
Just can't seem to find out how to get power to my boiler?
Any help, before I have to ring a plumber.
Thanks [/b]
anything showing on the LED display?
any obvious signs of water coming from the boiler casing or anywhere in the house? things you should look for before calling a plumber (water leaks in the house) or boiler engineer (water coming from the boiler)
check any circuit breakers and if you have a power cut, any lights working? did you check the new fuse was ok?
Yes its possible if you let all the pressure out of the system the pump could run dry & that could knock out the board
If you dont know how to bleed rads properly then DONT bleed rads!
