Ive done quite a few laminate flooring jobs and theyve all been successful.
Now im about to lay about 45sqm of 18(4) engineered flooring throughout my downstairs (part new extension). The floor is new screed and old quarry tile that has a new damp proof membrane already fitted.
The total area is an open plan 'L' shape that includes a lounge and kitchen/diner. I plan to run the boards against the 'L' shape not lengthways to reduce lengthg of runs.
I plan to glue all boards on all sides, all skirting is removed so I can hide ends without mouldings.
My main concern are the area's under the kitchen units. Rather than waste flooring under the units I want to leave this area un-floored.
Due to the total size of the floor could this cause an expansion problem as there will be a reasonable size of 'void' that the flooring could expand into?
Could I fill this space with plywood or similar and what underlay do you recommend? I am looking for a floor without the 'tap' noise I get from laminate.
Any advice would be appreciated
